It is currently Mon Jul 28, 2025 5:22 pm
 Post subject: Shorter Scale Lengths
PostPosted: Sun Feb 02, 2020 9:04 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Has anyone built with a Gibson 24.625" scale length?
The shortest I've done is Martin 24.9".
I know intonation gets trickier with shorter scale lengths and there will be tonal differences. I actually prefer the sound of Martin short vs. long. I'm re-topping a 13 fret L-00 I made that developed a severe belly because I experimented with opening the X a few degrees. It was Martin long scale but if I go to Gibson 24.625", it will turn into a 14-fret (almost) which is what I want.
Thoughts, opinions, experiences greatly appreciated.
Kevin Looker
I'm not a luthier.
PostPosted: Sun Feb 02, 2020 10:25 am
have used scale lengths down to 23 inches
most were on smaller parlor guitars
PostPosted: Sun Feb 02, 2020 11:23 am
My most common scale is 25". But I've done a fair amount of 24.625 and haven't noticed any real perceivable diffences that are noteworthy enough to require process change...
PostPosted: Sun Feb 02, 2020 1:33 pm
24.3 is the shortest scale I use so far and I didn't have any problems with intonation. That is to say it was no different then my normal guitar scale lengths.
PostPosted: Sun Feb 02, 2020 5:12 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I've used 23.5, 24, 24.82 scale lengths. None was a problem for intonation and no obvious difficulties appeared. All three pleased an experienced luthier and classical guitar player.
Peter Havriluk
PostPosted: Mon Feb 03, 2020 12:08 pm
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
I have copied an used as a model brazilian gianinni cl gtr with a a 600 mm short scale or just atad over 24in. I find it very easy to play for a cl since it has a narrower nut 47mm instead of the wider more traditional cl gtrs. at 52mm and wider
PostPosted: Mon Feb 03, 2020 5:49 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Thanks for all of the replies!
Greatly appreciated.
I'm not a luthier.
cron
