It is currently Tue Jul 29, 2025 10:04 am
 Post subject: Satin Nitro question
PostPosted: Sun Nov 17, 2019 6:36 am
Just finished spraying Satin nitro on my guitar body, it has a bit of a rough sandy feel to it but looks great.
Do I sand this flat? And what grit to use, don't want to create a shiny surface. I'm aiming for a Lowden type of satin finish.
Sent from my SM-G960F using Tapatalk
 Post subject: Re: Satin Nitro question
PostPosted: Sun Nov 17, 2019 6:38 am
Photo Image
PostPosted: Sun Nov 17, 2019 8:43 am
Satin finishes are generally an "as is - off the gun" type finish where no further work is required. As such a better quality gun that gives good atomization is prefered. Some finishers can achieve good results with less than first rate equipment, but that usually requires a level of experience most of us "finishing dilettantes" don't have.
A satin finish shouldn't have a rough sandy texture. That is usually from spraying a "dry" coat. You can try knocking it down a bit with some steel wool and see if you are still happy with the surface. If not, you might have to recoat it, possibly spraying a little heavier or adding a little retarder to get better flow out.
These users thanked the author Clay S. for the post: cablepuller1 (Sun Nov 17, 2019 9:13 am)
PostPosted: Sun Nov 17, 2019 9:06 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
NO! NO SANDING!!! satin must run as is off the gun..... The rough texture is dust and dirt. A surgically clean spray facility is required get good results.
Brian
These users thanked the author B. Howard for the post: cablepuller1 (Sun Nov 17, 2019 9:13 am)
PostPosted: Sun Nov 17, 2019 10:43 am
I've had some success smoothing rough bits and repairs (CA with waterbourne EV) with 2nd finest Scotchbrite, grey I believe. White scotchbrite will shine it up. May have to do the whole panel (top, sides or back) or even whole body to match it in.
Try it on test panels first.
These users thanked the author Colin North for the post: cablepuller1 (Sun Nov 17, 2019 10:54 am)
PostPosted: Sun Nov 17, 2019 12:43 pm
I had a similar issue when first sprayed. You do want as dust free as you can get . In my case it was the gun . I didn't have it adjusted correctly and was drying the material before it was hitting the surface. I adjusted the gun added 10% retarder and thinner. There is a bit of a learning curve. Agree nothing after spraying it smoothed out nicely
These users thanked the author bluescreek for the post: cablepuller1 (Sun Nov 17, 2019 1:39 pm)
PostPosted: Sun Nov 17, 2019 1:47 pm
Pretty sure Lowden are hit with steel wool at the end, or wire brush as they call it...
These users thanked the author meddlingfool for the post (total 2): MattM (Wed Nov 20, 2019 2:58 pm) • cablepuller1 (Sun Nov 17, 2019 2:00 pm)
PostPosted: Sun Nov 17, 2019 3:50 pm
yes lowden also uses a wipe on poly
These users thanked the author bluescreek for the post (total 2): MattM (Wed Nov 20, 2019 2:57 pm) • cablepuller1 (Sun Nov 17, 2019 3:53 pm)
PostPosted: Wed Nov 20, 2019 2:58 pm
First name: Matt
Last Name: M
City: Vancouver
State: BC
Hi John, thanks for your reply. Do you happen to have any details on Lowden's finishing process i.e. what wipe on poly they use and what the procedure is? I appreciate any tips you can provide
Matt
PostPosted: Wed Nov 20, 2019 3:34 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
I used General wipe on poly.
Really like the finish.
Didn't polish or anything,
left it as it is.
Only caveat is, when I tested on a piece of mahogany, it went all the way through the 1/8"
scrap.
I wouldn't use it on an acoustic for that reason.
Alan
Users browsing this forum: JimWomack and 10 guests
