It is currently Sun Aug 03, 2025 1:28 am
PostPosted: Tue Aug 14, 2018 3:54 pm
First name: Alain
Last Name: Gagnon
City: Ottawa
State: ON
Hello I’m looking for some tips on how to sand a softwood surface with a hardwood inlay such as a top with a rosette or the end wedge area. How can I sand these areas so the surface is even and flat without a raised hardwood inlay?
Alain
_______
PostPosted: Tue Aug 14, 2018 4:07 pm
If you don't have much to take off, back up your sandpaper with a hard level block, say MDF.
Clear the dust often to prevent grinding it into the softwood.
If there's more, then plane it first to very nearly level (careful for tear out) then sand with the block.
PostPosted: Tue Aug 14, 2018 4:17 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
This is the very reason I bought a drum sander.
It's a pain to do it well by hand, but what Colin said is your best strategy.
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Tue Aug 14, 2018 4:35 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
The Carruth scraper works really nicely for this, it even works with shell.
These users thanked the author Rodger Knox for the post: Pmaj7 (Tue Aug 14, 2018 5:59 pm)
PostPosted: Tue Aug 14, 2018 5:40 pm
I use an old block plane body and psa sandpaper. As you move to finer grits the dust discoloration becomes less problematic.
PostPosted: Wed Aug 15, 2018 6:30 pm
First name: Aaron
Last Name: Craig
State: Missouri
Make a sanding disc for your drill press from two or three pieces of MDF (cut with a fly cutter or circle router jig), countersink the bottom to accommodate a 3/8 to 1/2 in bolt and washer, cut the bolt head off with a hacksaw, look at the photos below for further detail, add some adhesive sandpaper, and go to town. This is a very handy little jig that can thickness all kinds of parts to close tolerances. Adjust the drill stop to your desired thickness and sand away in a fashion similar to a Safe-T-Planer.
Aaron Craig
PostPosted: Wed Aug 15, 2018 8:19 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
If working by hand, the unifying theme is to have an unyielding backer for the sandpaper. A cushy backer will conform around the harder material and sand the softer material faster, making flattening harder to achieve.
These users thanked the author doncaparker for the post: SteveCourtright (Fri Aug 17, 2018 4:46 pm)
PostPosted: Thu Aug 16, 2018 2:40 am
First name: Aaron
+1 Drum sander for tops/rosettes.
+1 Scraper for end grafts, but not sure why those are an issue - basically hardwood all around, yes?
+1 Hardwood (Milo) sanding blocks.
All of the above I guess, situation dependent.
PostPosted: Thu Aug 16, 2018 7:37 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I use low angle L/N vlnmakers plane , scraper, and then a sanding block with 180 , 220, and 320 grit.
PostPosted: Thu Aug 16, 2018 7:49 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We plane off what can be removed on rosettes and end grafts, then block sand with a ply block with 1/16" firm cork facing (rubberized gasket material is best, but the drawer lining peel and stick material from the big box stores works OK) and well radiused edges. With the CA we use on shell work and bindings, we often use a firm pad on a random orbit sander to level through the CA and any shell - we have several Dynabrade ROS with vacuum dust collection for the job, but most portable electric ROS will have a firm pad available. Also note that spruce may be sanded cross-grain where necessary with just a bit of along-grain sanding for cleanup. Finally, a 12" mill bastard file does a nice job of leveling where a scraper will hop around a bit and a block is overkill, like cleaning up that last bit of top binding near the tail graft or neck socket.
- Beth Brower
PostPosted: Thu Aug 16, 2018 10:14 am
" we often use a firm pad on a random orbit sander to level through the CA and any shell - we have several Dynabrade ROS with vacuum dust collection for the job"
If you only have one R.O. sander and you don't want to keep changing pads, something I have done to make a hard pad, is cut a circle of Formica and spray glue a used hook and loop sanding disc to the unfinished face. I then "hook" it to the sander and stick a PSA disc to the smooth face. The "hard pad" can then be removed like a typical H&L disc.
These users thanked the author Clay S. for the post (total 3): Terence Kennedy (Fri Aug 17, 2018 7:47 am) • TimAllen (Thu Aug 16, 2018 12:28 pm) • Pmaj7 (Thu Aug 16, 2018 10:32 am)
