It is currently Tue Aug 05, 2025 3:07 pm
PostPosted: Wed Jun 04, 2014 9:08 pm
First name: Kent
Last Name: Wilkinson
City: New Carlisle
State: Ohio
Zip/Postal Code: 45344
Has any body tried this. Does the wood discolor from the heat. I built a strum stick out of Purple heart that sounds great and has really good sustain. I thought I would like to try to build a Ukulele or Guitar out of it, if it can be bent.
PostPosted: Wed Jun 04, 2014 9:12 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
I've not used it, though I have a set. But I've seen guitars made from it. So I know it's possible.
These users thanked the author ZekeM for the post: Kent Wilkinson (Fri Jun 06, 2014 10:54 pm)
PostPosted: Wed Jun 04, 2014 9:14 pm
First name: Kent
City: New Carlisle
State: Ohio
Thanks Zeke
PostPosted: Thu Jun 05, 2014 4:08 am
First name: Michiyuki
Last Name: Kubo
State:
Country: Österreich
http://www.lonewolfguitars.com/options_ ... _wood.html
If you scroll to the "P" section you will find a good picture of a purple heart back and side set.
http://wiksnwudwerks.blogspot.co.at/201 ... heart.html
A blogger posted this.
I have seen other examples of purpleheart guitars but i can not find them so i found these to show ya. I think it looks pretty good, when the color turns i am not sure how they will look though. It is supposed to turns a rich deep purple brown so in the ase of the bloggers guitar that might be a good thing since it is so light, or maybe not haha. Purple heart is a fascinating wood to me, would love to see the end results in your project.
I have no info on heat exposure being an effect on color loss to the wood. I only knew that UV light exposure will turn the wood color. So best to keep it locked up in a safe, in the closet, in a dark room, doors and windows closed :) and then take it out only on the darkest of moonlit nights to play at the stroke of midnight. I jest of course. [:Y:]
久保
美智え
These users thanked the author Michiyuki Kubo for the post: Kent Wilkinson (Fri Jun 06, 2014 10:54 pm)
PostPosted: Thu Jun 05, 2014 5:33 am
First name: s
Last Name: g
Fylde guitars in the UK have made a few Purpleheart guitars.
http://www.fyldeguitars.com/custom_guitars/fanfret.html
http://www.fyldeguitars.com/personal_se ... ariel.html
These users thanked the author dash-x for the post: Kent Wilkinson (Fri Jun 06, 2014 10:53 pm)
PostPosted: Thu Jun 05, 2014 5:56 am
Fresh sawn purpleheart tends to be a nondescript brown color. Heat from the saw blade will sometimes make the surface turn the purple it will eventually become. A light sanding will change these areas back to the nondescript brown of fresh sawn wood. Bending with heat works much the same, but you may have to sand a bit more.
These users thanked the author Clay S. for the post: Kent Wilkinson (Fri Jun 06, 2014 10:53 pm)
PostPosted: Fri Jun 06, 2014 4:36 pm
First name: Kent
City: New Carlisle
State: Ohio
I noticed that on my build. When I hand sanded it it came back to purple. Thank you guys for all the info. I don't know any Lutherie's in my area. I can always get help when I need info on here. Thank you.
PostPosted: Fri Jun 06, 2014 9:42 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
I have some purpleheart binding I cut today. Got it in water soaking. Will try and bend it tomorrow or sometime this weekend. Putting it around(maybe) a baritone Uke. So we 'll see. Wish me luck.
These users thanked the author Lonnie J Barber for the post: Kent Wilkinson (Fri Jun 06, 2014 10:53 pm)
PostPosted: Fri Jun 06, 2014 10:56 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
A hardwood seller near me had some Purple Heart on display for a few years. After that, it was plain old brown. Never understood why he never changed it out for a fresh piece.
These users thanked the author Mike OMelia for the post: Kent Wilkinson (Fri Jun 06, 2014 11:16 pm)
PostPosted: Fri Jun 06, 2014 11:03 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
When I bought my piece I was told it would eventually change color.
These users thanked the author Lonnie J Barber for the post: Kent Wilkinson (Sat Jun 07, 2014 12:14 am)
PostPosted: Fri Jun 06, 2014 11:46 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Btw, it would seem toe if a good IV inhibiting finish were used, it would stay purple. I've asked questions in the past, but I've never learned of a true UV inhibiting finish, hard to believe they don't exist. Maybe just keep rubbed down with SPF 30?
These users thanked the author Mike OMelia for the post: Kent Wilkinson (Sat Jun 07, 2014 12:14 am)
PostPosted: Sat Jun 07, 2014 8:24 am
And a wide-brimmed hat!
PostPosted: Sat Jun 07, 2014 9:00 am
"A hardwood seller near me had some Purple Heart on display for a few years. After that, it was plain old brown. Never understood why he never changed it out for a fresh piece."
Maybe he was an "honest" hardwood seller and wanted to show people what it would eventually look like. Some purpleheart seems to stay purple, while other pieces seem to turn brown after a few years.
"Btw, it would seem toe if a good IV inhibiting finish were used, it would stay purple. I've asked questions in the past, but I've never learned of a true UV inhibiting finish, hard to believe they don't exist. Maybe just keep rubbed down with SPF 30?"
Most of the finishes I've used with "UV" protection seem to have color and only be semi transparent. Rub a little mud on your guitar, anyone?
PostPosted: Sat Jun 07, 2014 6:33 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Do you think copper tone might help?
PostPosted: Thu Jun 12, 2014 10:12 am
Last Name: Lee
Country: Wales U.K.
I made a purpleheart Irish Bouzouki about 3 years ago and it still doesn't have any "finish" on it. It is as purple today as it was when first worked. It is brown when freshly cut and turns back to purple on exposure to air and, I assume, light. The sides bent easily with a light spray of water.
These users thanked the author whiskywill for the post: Kent Wilkinson (Thu Jun 12, 2014 10:51 pm)
PostPosted: Thu Jun 12, 2014 10:53 pm
First name: Kent
City: New Carlisle
State: Ohio
The instrument in the picture. I was spraying my final coat lacquer on it. My 23 year old daughter walked by and bumped it. Fell 5 feet to concrete floor and the top shattered. So it's going back to the shop tomorrow.
PostPosted: Fri Jun 13, 2014 7:51 am
ouch!
PostPosted: Sat May 12, 2018 7:38 pm
Last Name: Colbert
City: Anacortes
In my experience, Purple Heart oxidizes to purple from brown after resawing..
PostPosted: Sun May 13, 2018 10:21 am
First name: David
City: Napa
Zip/Postal Code: 94558
Purple heart bends like a dream. I built a soprano Uke out of Purple Heart, bends easy and is stable,
Users browsing this forum: Ken Lewis and 43 guests
