It is currently Wed Aug 06, 2025 6:50 am
PostPosted: Tue Feb 27, 2018 1:42 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Anybody have any use for one of these in guitar building? Got a shiny new one in the box and I'd like to get some use out of it if I could.
Thanks, folks.
Peter Havriluk
PostPosted: Tue Feb 27, 2018 3:40 pm
The more I use it the more uses I find for it. It is as useful to the repair guy as it is to the builder. It can be used like a veneer saw, a plunge cutting saw, a scraper, a sander and polisher, grout and caulk removal tool- a multitude of uses. Like the smart phone it can replace a number of other tools by swapping out the accessory tool.
PostPosted: Tue Feb 27, 2018 4:08 pm
So far the only use I found for it on guitars was sanding the sides to fair in the bindings.
PostPosted: Tue Feb 27, 2018 4:15 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
How about quick bridge removal?
PostPosted: Tue Feb 27, 2018 4:22 pm
First name: Daniel
Last Name: Petrzelka
State: Washington
A Tonerite on steroids.
PostPosted: Tue Feb 27, 2018 5:47 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
But the Tonerite doesn't do a damned thing!
Peter Havriluk
These users thanked the author phavriluk for the post: Haans (Wed Feb 28, 2018 9:25 am)
PostPosted: Wed Feb 28, 2018 9:24 am
Why I used Prime Vibe. It vibrates the top with music...what a concept!
As far as oscillating tools, fit with the triangular sanding plate, it's great for taking a bridge down a bit and re-contouring the center of bridges after they are glued on the top.
PostPosted: Wed Feb 28, 2018 9:32 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
With the set removed from the bottom side of the mid-width blade, excellent tool for cutting the neck off on epoxy-glued Yamahas for conversion to bolt-ons. With some tape on the body, minimal chance of finish damage and does a nice job getting through the dovetail.
- Beth Brower
PostPosted: Wed Feb 28, 2018 12:16 pm
You can carefully saw off the top or back for possible reuse, without losing too much depth in the sides.
You can plunge cut the slots for a classical guitar.
You can profile the sides and trim them to length after bending.
You can plunge cut the sides and bottom of the neck block mortise and chisel out the waste, then cut the matching tenon in the neck.
You can trim and notch braces.
Using a "raking" motion with the half moon blade you can relieve the area where the neck bolts to the body (for bolt on necks)
Again using a "raking" motion and various saw blades do some light carving on different places on the neck (chin, heel, peghead, etc.)
I'm sure there are many other uses.
Users browsing this forum: No registered users and 44 guests
