It is currently Thu Aug 07, 2025 9:15 am
 Post subject: Delaminated in Seattle
PostPosted: Sat Dec 09, 2017 11:26 pm
This is Gurian purfling attached with CA. The ca held fine! I suspect I got it too hot. I was bending at 300, but it briefly hit 380 (the blanket anyway)
Am I right in thinking it was the Heat?
Also, I did use tape. However only three places and I did not tape the middle of the waist or the top of the upper bout, the two places where it delaminated.
I'm thinking I will still be able to use them if I just get them locked in there nice and tight. Thoughts?
PostPosted: Sun Dec 10, 2017 12:05 am
I had some bwb from LMI delaminate just with bending it for insertion so I bought from Gurian. No problem with some but others delaminated the same way.
I called Gurian and it turned out I ordered seconds. There is a code in the product description that identifies them as seconds and they are cheaper.
They replaced them with top quality and I have had no problems. Might want to look at the product code and give them a call.
As far as bending I tape the binding together with only small gaps between the pieces of tape and have had no issues. I go to 300. I think more tape would definitely help.
These users thanked the author Terence Kennedy for the post: Pmaj7 (Sun Dec 10, 2017 2:48 am)
PostPosted: Sun Dec 10, 2017 10:41 am
The purling in the second photo can probably be reattached, but that first one with multiple buckling is toast.
These users thanked the author Barry Daniels for the post: Pmaj7 (Sun Dec 10, 2017 2:32 pm)
PostPosted: Sun Dec 10, 2017 1:13 pm
Well, binding can be a real,drag with a delaminated purflings. 380 is too much heat IMO.
I would spritz the buckled bits with water and try to flatten with the clothes iron. It's amazing what that can do to restore order.
These users thanked the author meddlingfool for the post: Pmaj7 (Sun Dec 10, 2017 2:32 pm)
Users browsing this forum: Gasawdust, Kbore, ptourin and 25 guests
