It is currently Tue Aug 12, 2025 10:03 pm
 Post subject: complicated rosette
PostPosted: Wed Dec 21, 2016 6:15 pm
First name: Thomey
Last Name: Dertien
City: Sioux Falls
State: SD
Zip/Postal Code: 57106
im going to start on my 3rd guitar and want to attempt a rosette similar to these. i have an idea how some of it is done but not all of it. does anyone know of any videos or pictures of the prossess. i have the circle cutting jig for a demel from stem mac. id does not plung cut which would be nice. im assuming you chisel the breaks in the circle but i would like so see the right way to go about it.
 Post subject: Re: complicated rosette
PostPosted: Wed Dec 21, 2016 11:17 pm
I've not seen any videos of this type of rosette....The guys who make these deserve A LOT of credit for their artistic presentations IMO. So..... I think it best when people just figure it out.......there's little left on guitar making that hasn't been shared which might just not be a bad thing...
Get a piece of plywood and just practice with scraps...... it might be easier than you think...
PostPosted: Thu Dec 22, 2016 2:54 pm
Last Name: Beaver
City: Lake Forest
I can imagine a circle cutter for the radius lines and a straight edge for the radial lines. Beyond that I would say it's all design and technique. I suppose that is where the artist emerges. (In other words I don't have a clue)
Joe Beaver
Maker of Sawdust
PostPosted: Thu Dec 22, 2016 3:43 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
laughing6-hehe Never done one, but if I am also planning one of these on my next round of builds. Here's my plan.
1. cut a whole rosette
2. segment the rosette (and any others of different sizes)
3. Mitre and add all of the purfling
4. Establish the sizes of the inner and outer channels (and any others of different sizes)
5. double check the size with calipers
6. draw out your design as precise as possible (would use AutoCAD or something similar that allows precise plotting
7. Attach drawing to soundboard
8. Route out the major chunks
9. score the remaining corners for each segment with a straight edge/circle cutter with a razor blade
10. repeat until the scores are the required depth
11. remove the remaining material with small, razor sharp chisels.
12. inlay
Easy right? should be able to knock it out in a day or two...or maybe a month after several failures! gaah laughing6-hehe gaah laughing6-hehe
Since there aren't any tutorials, maybe you can post some results in this thread so that the rest of us can get our learn on :)
PostPosted: Thu Dec 22, 2016 3:53 pm
If you look at this thread it shows how to do some of the chisel work :)
http://www.acousticsoundboard.co.uk/thr ... /strand-om
To be someone must be a wonderful thing!
PostPosted: Mon Dec 26, 2016 2:47 pm
I'd be prone to make the channels, and then fit the pieces to them. You'll want to set up stops for whatever tool you use to outline the curved parts, and work out the process so that you won't have to move the stops to reset the radii for the inside and outside cuts. One possibility would be to temporarily glue the stops to the top with a drop of CA. You'll need to smooth off that surface anyway after you've put in the rosette, so it won't be a problem as long as you don't get carried away with the glue.
Once you have the inner and outer limit cuts for the arcs you can make the radial cuts. Some sort of a rule that pivots on the same pin you used for the arcs would be handy here: I'd make one out of plexi. This could be clamped down to hold it firmly in place while you make the cuts, being careful about the grain direction. Some of the cuts could be best made with a double knife: at it's simplest, just two Ex-Acto blades taped together with a shim in between to make a cut the exact width of the purfling you're using. You'll need a tiny chisel to clean out the groove, such as the ones violin makers use for the purfling channel.
This will be somewhat rime consuming, but fancy work always is. Just take your time and work really carefully, and it should come out fine.
PostPosted: Mon Dec 26, 2016 11:19 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
Use a router bit the width of your most narrow purfling. I use a .030 wide router bit, same width as my fiber. Also cut out your parts at the same time with the same router setting and they will drop right in. You will need to make another pivet to cut out your parts.
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
PostPosted: Tue Dec 27, 2016 3:23 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Regardless of HOW it is done, making it look good is the hard part. Good design is dam hard and critical. Do a LOT of work with pencil and paper first. Pencil is easy to correct or change. Wood in your guitar top is not so easy.
As with a lot of these things, its probably easier than it might appear. Think it through to its base procedure, and make sure that your design cooperates with your ability to execute it.
http://redrivercanoe.ca/
These users thanked the author douglas ingram for the post: James Orr (Tue Dec 27, 2016 3:49 pm)
PostPosted: Tue Mar 14, 2017 8:27 pm
First name: Matt
Last Name: Bobertz
City: Geneva
State: FL
Zip/Postal Code: 32732
I actually tried one similar to this. I used Alan's method, but rigged up a means of using the dremel cutter for the radial cuts. For a radial cut I set up a couple blocks of wood to keep it from drifting side to side then turned the radius adjusting screw with the dremel on.
I attached a pic. Hope it shows up (I'm not sure how to use this forum quite yet)
PostPosted: Thu Mar 16, 2017 3:25 pm
First name: Allen
Last Name: McFarlen
City: Mt. Sheridan
State: Qld.
Zip/Postal Code: 4868
I've been doing the stopped tile and purfling rosettes for years. It's been an evolution of technique and design.
I now use a combination of CNC and laser that cuts the job down to about 1/2 hour instead of a day or more. However I started out with circle cutter with blade to score the sound board and cut the tiles in my veneer, dremel, scalple and chisels for the other work.
It's going to be a very laborius job and to get clean results needs to be done in stages and is built up in layers so to speak. Starting with the large tiles you inlay them and then let dry. Then come back and add your next element, let it dry and finally the purflings.
I went through my Facebook page and found one that I documented for a client.
Allen R. McFarlen
Facebook
Cairns, Australia
PostPosted: Thu Mar 16, 2017 4:18 pm
Last Name: Beaver
City: Lake Forest
Very nice Uku Allen. Love the rosette
Joe Beaver
Maker of Sawdust
PostPosted: Thu Mar 16, 2017 4:53 pm
First name: Trevor
Last Name: Gore
City: Sydney
When requested to do this style, I cut the inlays first to get the radial dimensions and leave them over-length. With the same shop-made precision circle cutter, I can then creep up on the radial dimensions of the pockets to get a perfect fit, then square the ends of the pockets (chisel) and trim the inlays down to length.
For this type:
I use a pattern routing template that I made and framed the inlaid tiles in-situ.
http://www.goreguitars.com.au
PostPosted: Thu Mar 16, 2017 10:17 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Man!! Love this stuff! Great work!!
PostPosted: Fri Mar 17, 2017 12:18 am
Last Name: Beaver
City: Lake Forest
Trevor, You certainly do beautiful work!!!
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: Trevor Gore (Fri Mar 17, 2017 8:04 pm)
PostPosted: Fri Mar 17, 2017 12:45 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
I have always wanted to do ones like Mr McFarlen. Thanks Allen for showing the method - and with an oval, just for added degree of difficulty! Can't wait to give it a try - but I can see why you would be drawn to using CNC instead.
