It is currently Wed Aug 13, 2025 2:50 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Gap under fretboard
PostPosted: Mon Jan 09, 2017 11:52 am
I would also recommend you redo it. However, I'd you insist on filling it then you should use wood. Remove the glue and fit wood into the gaps..
PostPosted: Mon Jan 09, 2017 2:09 pm
First name: George
City: Seattle
jshelton wrote:
Why stop there? It looks like the gap continues up the neck, that's why I asked if the fingerboard was cupped. What are you going to do about the glue showing in the gap? If you're going to fill it there are lots of products from black epoxy to standard wood fillers. None of which would be satisfactory in my opinion.
While I, too, would remove and redo, some very experienced builders have stated they didn't think that was necessary. While I can imagine ways to fill the gaps between the shaft of the neck and the fingerboard, I don't know how I would go about filling the highlighted area without making a mess of things.
Just curious,
George :-)
PostPosted: Mon Jan 09, 2017 7:18 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
this thread interests me as a thing like this has happened to me. not as severe but equally baffling. i am sure fingerboard and neck/top were a good, gapless fit in the dry run. spanish foot classical guitar, neck glued at an angle, fingerboard planed on its back from the 12th fret to accommodate it. after gluing it, a back appeared around the 10-12 the frets on the treble side. still can´t figure what happened. i had a lot of clamps there.
anyway, i ended up removing the fingerboard and gluing a new one. guitar turned out ok.
PostPosted: Mon Jan 09, 2017 8:14 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
Depending on the wood, sometimes the water in the glue can cause cupping. I had this happen on one guitar where the plywood clamping caul was not quite wide enough. I made a larger one to insure the edges are directly under clamping pressure and haven't had it happen again.
Really bugged me at the time, but so far I've kept all my guitars, and I couldn't tell you which one it happened on!
