It is currently Sat Aug 16, 2025 1:07 am
PostPosted: Fri Mar 25, 2016 9:52 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I have a harp guitar I'd like to finish. Original design was 12 fret, but I'd like to change to 14. Seems the price I'd pay is possibly having to extend the bridge plate back. Hopefully won't bump into a tone bar. Question is, what roughly us the shift amount?
PostPosted: Fri Mar 25, 2016 10:30 pm
Last Name: Kincheloe
Changing from 12 to 14 moves the bridge closer to the X intersection, not the tone bars. Risk of bridge pin holes destroying the X, unless you're using a pinless bridge. Have you braced the top already?
The shift is around 1 3/8" (just subtract 12th fret position from 14th position). You could also change to a longer scale to keep the bridge closer to its original location.
PostPosted: Fri Mar 25, 2016 10:49 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Thanks Dennis. I'll do some measurements to see. 1 & 3/8"?
PostPosted: Fri Mar 25, 2016 10:50 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
While I got u here, tuners, what u recommend? Another thing I hate is using bridge pins as string risers. Is there anything available in brass?
PostPosted: Sat Mar 26, 2016 1:23 am
For the harp strings, unless you're using a design where you can have the keys sticking out to the side, then Pegheds are the best and lightest weight that I know of. Expensive though. Especially the 16:1 ratio. I use 4:1, which is very touchy. Too touchy on neck strings, I've decided. Not too bad on harp strings. I'll be going to a slothead next time so I can use normal tuners, but probably still 4:1 on the harp strings.
I have the harp strings run straight from the tuners to the bridge, so I can't advise on risers. But I do need to try shoving something under one of the strings and see what it does to the sound, and if they're worth including next time. Or maybe pins to bend the strings horizontally to create a break angle. Certainly could use brass rod stock for that. Or maybe brass tubing with wood core, for aesthetics and the tiniest bit of weight savings :)
On second thought, I do have an idea for string risers... bass guitar fretwire. Glue a block of wood onto the harp headstock with a strip of that in it, so all the strings go up and over it like a saddle.
PostPosted: Sun Mar 27, 2016 2:33 am
Last Name: Schreiner
City: Miami
State: FL
Zip/Postal Code: 33183
I use bone bridge pins as sub-bass risers on my HG builds.
Michael
PostPosted: Sun Mar 27, 2016 10:23 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Nice work Michael, what style tuners are you using?
PostPosted: Mon Mar 28, 2016 9:27 am
City: Miami
State: FL
Thanks Mike. I use 6 single Schaller SB4 Banjo tuners from Lmii. The other 6 tuners are Schaller M6 Mini 6 on a side from my local music store ( I own a music store). They come with small metal buttons which I replace with a set of #3057 large pearloid buttons from Stewmac.
Michael
Users browsing this forum: NikolayUsalf and 20 guests
cron
