It is currently Sat Aug 16, 2025 11:18 pm
PostPosted: Thu Oct 15, 2015 10:20 pm
First name: Ringo
I have been charged with bending some old mahogany sides that are super brittle perpendicular to the grain... it snaps in two easily when pressed like this:
Any advice for bending on a fox bender? I'm thinking high heat, very little water, and go very slow but if anyone has some tricks up their sleeve I'm all ears...
PostPosted: Thu Oct 15, 2015 10:40 pm
Adding SS2?
PostPosted: Fri Oct 16, 2015 2:30 am
Does that look a bit like run-out to anyone else?
These users thanked the author Colin North for the post: Ken Jones (Fri Oct 16, 2015 11:05 pm)
PostPosted: Fri Oct 16, 2015 5:47 am
sometime it just doesn't want to be a guitar.
I would use
slat wet paper wood ( treated with SS@) wet paper blanket then top slat.
start bending at 275 on the lower bout. then upper then waist checking to be sure the wood is damp. then take to 350 F . Once the temp is reached turn off and let cool . I may cycle a 2nd time to 250 to get the water out.
PostPosted: Fri Oct 16, 2015 6:53 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I/m bending old walnut bindings now sand to .065, I soak the bindings for at least 1 hr, 3hrs for bloodwood and proceed with john /s instructions above
PostPosted: Fri Oct 16, 2015 7:41 am
The way that is breaking I don't think you going to have much luck. :(
How about laminating it with qs Hog on the inside? Might just work.
PostPosted: Fri Oct 16, 2015 11:44 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
That's going to need to be very thin, maybe even less than the .065" recommended.
I've gone down to a little less than .06" with bloodwood, but that's much denser than mahogany.
John's instructions probably have the best chance of working.
PostPosted: Fri Oct 16, 2015 12:13 pm
First name: Ringo
I am starting to think this might be the only way... a couple of .05" laminations. Oh well I'll try it at .08" first and see how it goes. It's a dread so the curves aren't too severe... wish me luck folks
PostPosted: Fri Oct 16, 2015 12:57 pm
Good luck James. Take it slow
PostPosted: Fri Oct 16, 2015 11:10 pm
That's exactly why I adopted the "flatsawn-to-quartersawn" approach (discussed in another thread) to cutting my linings -- it eliminates runout, and consequently, breakage during bending.
Mountain Song Guitars www.mountainsongguitars.com
PostPosted: Wed Oct 21, 2015 7:27 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Ken, would u please link that thread here?
These users thanked the author Mike OMelia for the post: qrwteyrutiyoup (Wed Oct 21, 2015 7:53 pm)
PostPosted: Wed Oct 21, 2015 10:43 pm
First name: Ringo
Oh well, didn't work. This wood just has zero strength... I thinned to .08", sprayed w/ supersoft II, then bent really hot and slow the next day, so hot I thought it would char the wood. Failures were just in a couple of spots but being mahogany it sticks out like a sore thumb. To think... all the crazy tight cutaways I've bent with no problems but I couldn't even pull off a dreadnought shape with this stuff. :Sadface.
PostPosted: Wed Oct 21, 2015 11:36 pm
If you have more, try going to .04 and doing double sides?
PostPosted: Thu Oct 22, 2015 5:58 am
hot and slow is not what you want. you should be done bending in 4 minutes.
be sure you have moisture .
PostPosted: Thu Oct 22, 2015 6:13 am
Just chuck it.
