It is currently Sun Aug 17, 2025 6:51 pm
 Post subject: finish gun pressure?
PostPosted: Mon Jun 15, 2015 2:31 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Just curious as to what pressure I should be running my gun at.
I have an old Binks touch up gun, and usually set the copressor to 25-30 lbs.
I recently bought a Finex gravity feed hvlp gun,
and am trying to dial in the pressure, and had some new thoughts.
Should I have a gauge at the gun, and go with the pressure as the gun is operating?
I have been shooting shellac at a 1 1/2 lb cut.
I want to get better results, so I don't have to do so much sanding at the end.
Any advise would be appreciated.
Alan
 Post subject: Re: finish gun pressure?
PostPosted: Mon Jun 15, 2015 4:37 pm
City: Tyler
I pretty much ignore my gauge. I just hold the trigger down and increase the pressure until I get good atomization and pattern. Obviously, I start with the air flow control screw on the gun at stopped. Too much pressure and you're just blowing finish all over the place. Just takes a couple seconds and a couple trigger pulls. This works for me.
PostPosted: Mon Jun 15, 2015 5:59 pm
First name: alan
City: Santa Rosa
State: ca
Thanks Glen.
That's pretty much what I do.
Alan
PostPosted: Tue Jun 16, 2015 7:37 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I run a regulator right at my gun. static feed pressure is usually around 80psi, constant flow pressure is around 25-30 psi. Here is a link to an article i did a little while ago on setting up a spray gun and proper use.
http://howardguitars.blogspot.com/2015/ ... brian.html
Brian
These users thanked the author B. Howard for the post: Glenn_Aycock (Wed Jun 17, 2015 5:23 pm)
PostPosted: Tue Jun 16, 2015 11:32 am
First name: alan
City: Santa Rosa
State: ca
You rock, Brian!
Exactly what I needed to read.
I'll give that a go, today!
Last coat on an instrument called a phin,
pronounced pin.
Alan
Users browsing this forum: peter.coombe and 9 guests
