It is currently Sun Aug 24, 2025 5:08 pm
PostPosted: Tue Apr 19, 2011 9:14 am
I have a friend who's asked me to work on one of these. I've never worked on this or a banjo before. He says that the neck keeps moving, the action and tuning aren't stable. He believes it has something to do with the center rod that supports the neck and body. Sounds logical to me. Any advice on diagnosing/fixing the problem, if and when I get my hands on the thing?
PostPosted: Tue Apr 19, 2011 9:29 am
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
Common banjo problem. The neck joint to the rim is probably loose. Just like guitars, the wood dries out and joints get loose. After you get it in your hands, you'll see what the problem is.
PostPosted: Tue Apr 19, 2011 10:10 am
I always disliked working on banjos for just this reason.
Replacing heads was a pain in the butt, too.
PostPosted: Tue Apr 19, 2011 5:22 pm
Last Name: Ball
The biggest cause of that problem from what I've seen is a neck joint that doesn't really fit perfectly. True, banjo necks will loosen up as the wood moves, but the banjos I've seen with really bad staying in tune issues have had less than perfect neck joints. If the neck is only contacting the rim with a small surface area, any movement of the wood is accentuated. Also, guitjos have a lot more string tension on them than regular banjos, and this makes the problem even worse.
A lot of the really classic, high-end old banjos have horrible neck fits--they're frequently undercut in the middle so that the neck looks like it's mating with the rim really tightly, but is in fact only contacting the rim around the edges of the heel. A lot of them look like they were fit with a hatchet when you take the necks off. It's amazing how much tone is lost that way, along with stability of the neck joint....
PostPosted: Tue Apr 19, 2011 7:09 pm
So, can you just tighten this up somehow, or is the fix a little more involved?
Users browsing this forum: Freeman and 23 guests
