It is currently Wed Aug 20, 2025 1:31 am
PostPosted: Mon Aug 30, 2010 7:11 am
First name: Tim
Last Name: Warren
State: Ok
Zip/Postal Code: 73020
Anyone have a set of plans for the Holstein / Walker Side Bender?
Tim
PostPosted: Mon Aug 30, 2010 8:27 am
Last Name: A
Google - is your friend idunno
http://www.lint.org/TechNotes/lowcostbender.html
PostPosted: Mon Aug 30, 2010 8:29 am
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
Here's what I found when I googled 'Holstein / Walker Side Bender'.
http://www.lint.org/index2.html
There don't seem to be plans available. You just make up your own.
Or go to the LINT site and contact Holstein or Walker.
Dan
PostPosted: Mon Aug 30, 2010 8:33 am
First name: Dan
City: Brooklyn Park
State: MN
John and I were googling simultaneously. But not in the same room!
PostPosted: Mon Aug 30, 2010 8:38 am
Last Name: A
My google was faster :D
PostPosted: Mon Aug 30, 2010 10:04 am
"John and I were Googling simultaneously, but not in the same room!"
Do we have a problem here? There should be a law! :D
PostPosted: Mon Aug 30, 2010 10:43 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Lots of people use that kind of bender as it is simple and cheap to build, and since you need to build a bending form with any method. The clamping methods are quite diverse, some use turn buckles some clamps and except for the waist springs will work well.
Here is a video of a similar idea with a cutaway bender added, he uses clamps for waist.
Fred
Fred Tellier
PostPosted: Mon Aug 30, 2010 11:23 am
Bo never intended for there to be plans. However, he has received enough interest that he has produced some kind of plan. Just follow the contact info on the LINT webpage, and Bo will get back to you.
Matt Jacobs
"Don't tase me bro"
PostPosted: Mon Aug 30, 2010 1:26 pm
Last Name: A
Fred,
You were much younger when you made that video.
PostPosted: Mon Aug 30, 2010 8:03 pm
First name: Fred
Last Name: Tellier
City: Windsor
That's not me at any age.
Fred
Fred Tellier
PostPosted: Mon Aug 30, 2010 8:32 pm
the one thing I would ask is to not use light bulbs. I know of 3 people that lost their shops from light bulb benders. They can cause a fire. Heat blankets are so much safer. Just food for thought. I want you to be safe.
PostPosted: Mon Aug 30, 2010 8:52 pm
Last Name: A
agreed - why take the risk ?
PostPosted: Tue Aug 31, 2010 4:47 am
First name: Tim
Last Name: Warren
State: Ok
I did google it, thats how I found it. I found a sire that showed 1 page out of 4 of the plans. I was just hoping someone had built one and had a copy of the full plan.
John I agree. I think it would be almost like putting a piece of wood in the oven. Might get away with it 10 times but the 11th will burn like crazy.
Fred, thanks for that video. Are you saying NOT to use springs for the waste?
Is there a better way to build it or are they all basically the same when it comes to home built?
Tim
PostPosted: Tue Aug 31, 2010 6:57 am
I started out buiding a very simple bender for my early guitars, but found it did the job perefctly well, and something like 80 sides bent since have never had a breakage or felt I wanted anything different. I make a new one (takes all of an hour) for each new body shape, but then you have to do that with a Fox style one as well. I use a blanket and slats from John Hall.
PostPosted: Tue Aug 31, 2010 8:06 am
And if you do use light bulbs...or even blankets, set up a timer for when you forget.
I use both bulbs AND blanket. I NEVER leave the bender during the time the heat sources are on. I even set an alarm on my cell phone...just in case.
PostPosted: Tue Aug 31, 2010 8:51 am
I use a heating blanket because it works better. When I used light bulbs, however, I found that lining the inside of the bender and the mold with aluminum tape was essential. Once I did that, there was no scorching at all.
Users browsing this forum: DennisK and 17 guests
