It is currently Sat Aug 16, 2025 12:08 pm
 Post subject: Bridge plate stock
PostPosted: Fri Feb 19, 2010 12:42 pm
I have on the left a piece of maple from stewmac and on the right maple from LMI. The stewmac, as you can see, back sawn and the one on the right is quarter sawn. What is the preferred choice of the professional luthier?
Bro. Matthew A.
Oklahoma
 Post subject: Re: Bridge plate stock
PostPosted: Fri Feb 19, 2010 12:52 pm
First name: Christian
Last Name: Schmid
City: Edmonton
State: AB
Zip/Postal Code: T6E 1P9
rift-sawn :mrgreen:
PostPosted: Fri Feb 19, 2010 1:50 pm
Actually the one from SM is riff sawn or at least every one i have ever recived from them. (look at theend grain to tell) it is an angle closer to flat than LMIs but I suspect that LMIs is also riff sawn just at an angle closer to quarter that the SM
PostPosted: Fri Feb 19, 2010 2:35 pm
You are probably correct. I can tell that the end grain on the right one are riff sawn also. The one on the right's grain is much straighter. Which would you use?
Bro. Matthew A.
Oklahoma
PostPosted: Mon Feb 22, 2010 11:03 pm
If you had to pick, which one? Left or right?
Bro. Matthew A.
Oklahoma
PostPosted: Tue Feb 23, 2010 1:17 am
Last Name: Abercrombie
What are you using them for?
PostPosted: Tue Feb 23, 2010 10:01 pm
bridge plate
Bro. Matthew A.
Oklahoma
PostPosted: Tue Feb 23, 2010 10:13 pm
Because of the stresses imposed by the strings, a quartersawn bridgeplate will tend to crack along a grain line. A riftsawn plate is less likely to do so, at least in theory.
In Markham,Virginia
Users browsing this forum: CarlD, Powdrell1 and 17 guests
