It is currently Sat Aug 16, 2025 10:29 am
PostPosted: Tue Feb 02, 2010 2:32 pm
Is there a good way to sharpen a router bit? Any guidance is appreciated...
PostPosted: Tue Feb 02, 2010 2:56 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
I think it's better to give it to experts... But, you might want to know that the bit will loose of its precision (maybe a 1/2 bit will become a 15/32, by example), whatever the way you sharp them. So, for the price that cost a bit, maybe it's better to buy a new clean, sharpie and precise one.
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Tue Feb 02, 2010 3:35 pm
First name: Randolph
Last Name: Morris
A router bit will always become a bit distorted as a result of being sharpened regardless of who does it by virtue of the fact that the edge is angled. You always sharpen the flat side of the bit (never the angled side). This will remove a tiny amount of carbide and the new edge will be slightly down the angled edge from where it was originally. This is usually no issue at all. On a flush trim bit, however, the bit will come slightly out of alignment with the bearing and no longer trim exactly flush. You can take care of this by wrapping a piece of tape around the bearing to make up the difference.
Use a diamond stone and just rub the flat side of the bit on it. It works great in a pinch, but after a few times of this it is better to send it in to someone who has a good sharpening system. The small bits are probably cheaper to buy new. Hope this helps.
PostPosted: Tue Feb 02, 2010 3:54 pm
I don't bother , most router bits are very economical. Carbide takes special tooling to sharpen and I was never happy with the end result . Buy new ones.
PostPosted: Tue Feb 02, 2010 5:41 pm
Last Name: Bartley
City: Monteith
Zip/Postal Code: P0K1P0
I'm not sure about this (above). When you sharpen a router bit, the sharpening happens on the cutting face (the flat face). Because the back side of the cutting edge has a relief ground on it (a few degrees of angle), the diameter of the flush trim cutting bit is slightly reduced (a few thousandth's on each sharpening). Wrapping tape around the bearing will only increase the amount of clearance between the bearing and the cutting face, and will leave even more waste to remove with a file, scraper or sandpaper.
cheers
PostPosted: Tue Feb 02, 2010 5:54 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Throw it in the trash and but a new one.
James [:Y:]
James W Bolan
Nashville Tennessee
PostPosted: Tue Feb 02, 2010 5:56 pm
Last Name: Morris
John, you are right about this. Viva la dislexia!! :)
PostPosted: Tue Feb 02, 2010 6:51 pm
I have a small Fallkniven DC3 combination Diamond/Sapphire stone which you can touch up an edge with to give it a little more life, though its a compromise not as good as a new/resharpened but will extend the life
Formerly JJH
PostPosted: Tue Feb 02, 2010 6:58 pm
First name: Jim Howell
If you are going to do it at all, take it to a pro. I've had fair luck with the person who does this though our local WoodCrafter store.
For bits that really need to be sharp, like routing channels for binding, etc., take John's advice and toss them.
Jim Howell
Charlotte, NC
PostPosted: Tue Feb 02, 2010 7:36 pm
So, you guys are suggesting to toss the LMI down sheer bit they sell for cutting binding channels instead of sharpening it?
Maybe that's the way to go... How many binding jobs should one get out of a bit???
PostPosted: Tue Feb 02, 2010 8:33 pm
Fine diamond honing stick. Same number of passes on each blade. 3-4 swipes should do it.
PostPosted: Wed Feb 03, 2010 4:39 am
I'm with Howard for Rod's reason.
For a couple of years now I've been using a diamond sharpener to touch up the flat faces of router bits.
Helps to clean off any resin/oil build up on the face first.
PostPosted: Wed Feb 03, 2010 10:11 am
Last Name: Cox
I think it probably is important to clean off the trash...
The thing I worry about (Though it may not be an actual problem) is balance...
Things spinning up at 24,000 rpm vibrate like crazy if they aren't balanced right...
I think on a binding bit, I would probably buy a new one.... though I think the duty cycle on a Carbide bit should be quite a bit longer than 1 or 2 guitars...
PostPosted: Wed Feb 03, 2010 12:22 pm
I had bad luck with my local machine shop, so mileage may vary. I now send my SM binding bits to Highland Woodworking sharpening service and they're as good as new, and it's inexpensive.
For most bits I just buy new as well, but binding and pattern bits are expensive.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Wed Feb 03, 2010 10:55 pm
First name: René
City: Bossier City
State: Louisiana
Check out these diamond mini-hones, they're not expensive and would have other uses around the shop if you don't like them for router bit sharpening.
http://www.woodcraft.com/Family/2005910 ... -Hone.aspx
René
PostPosted: Thu Feb 04, 2010 12:44 am
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
Dyslexics of the world Untie!!!
Darrin
PostPosted: Thu Feb 04, 2010 6:44 am
Join ADN!
National Dyslexics Association
PostPosted: Thu Feb 04, 2010 9:50 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Laurent,
I have the LMI kit. Do you think Highland can do this bit? And what would you estimate the cost to be including shipping?
PostPosted: Thu Feb 04, 2010 10:01 am
If you are using a bit with a bearing on it, wouldn't it change the clearance, slightly? Might not be enough to worry about, if you leave your bindings proud.
PostPosted: Thu Feb 04, 2010 11:40 am
I think the LMI rabbeting bit is more standard than the SM one, and you may be able to find an inexpensive replacement. I'd start looking at the Grizzly rabbeting set #1, with which the SM bearing are compatible BTW.
Highland Woodworking subcontracts a shop in NJ to do this:
http://www.highlandwoodworking.com/saw-sharpening-service.aspx
It's less than $5 for a bit, they'll sharpen most bits and blades, and they're good.
Waddy, they take very little carbide off the flat edge (less than .0005"?), it is not noticeable. Theoretically, after a few sharpenings the bearings will have different values.
Laurent Brondel
Users browsing this forum: CraigG and 8 guests
