It is currently Tue Aug 12, 2025 4:13 pm
PostPosted: Sun Nov 29, 2009 4:39 pm
Last Name: Morgan
Hello all,
Is there a need to use pore filler ie z-poxy for spruce tops/cedar tops? Is shellac enough prior to finishing? Also, Bocote seems like a wood w/ little or no open pore structure, so is it necessary to fill, or will the shellac and finish take care of it?
Many thanks for the replies,
Remember, to always plant trees under which you may never sit.
PostPosted: Sun Nov 29, 2009 6:37 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
Spruce and Cedar are closed-grained woods and don't need to be filled.
It's been 25 years since I've worked with Bocote but I seems to rememeber
that it was an open-grained wood in need of filling. But my memory has fooled
me more than once - as far as I can remember.
PostPosted: Sun Nov 29, 2009 7:00 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Spruce shouldn't require filler. I've never used Bocote, but you should be able to tell if it needs filling by the way it looks with wet shellac on it.
PostPosted: Sun Nov 29, 2009 7:15 pm
First name: Erik
Last Name: Hauri
State: Maryland
You need to pore fill bocote - its pore quotient is about the same as walnut or mahogany.
The member formerly known as erikbojerik....
PostPosted: Sun Nov 29, 2009 10:18 pm
Last Name: Morgan
Thanks for the replies Gents. I am always amazed and humbled by the constituents of this forum.
Cheers,
Users browsing this forum: Chris Pile and 45 guests
