It is currently Tue Aug 12, 2025 7:38 pm
PostPosted: Sat Nov 07, 2009 4:48 pm
First name: Heath
Last Name: Blair
City: Visalia
part of the connector for the 9 volt battery jack on an LR Baggs "double barrel" pickup came off. is there a way to replace just the battery jack or is the pickup lost?
also what would be a good starting place for placement of the condenser mic? it came loose long ago and i cant remember where it was attached.
thanks in advance.
sweat the small stuff.
PostPosted: Sat Nov 07, 2009 6:44 pm
Go to Radio shack (or whatever its called these days - its the Source here in Canada) and buy a new 9 volt end .. cut and strip the end of the old one, put some shrink wrap on (dont heat it yet), and solder the new end to these wires. Then move the shrink wrap over, and heat that as protection and insulation on the joint. Good as new.
PostPosted: Sat Nov 07, 2009 6:47 pm
It's easy to replace the battery jack. You should be able to buy one at Radio Shack or Circuit City or The Source (I forget what it's called these days in the US). Cut out the old one and splice the wires to the new one. Cover each joint with electrical tape or, better, some shrink tubing.
PostPosted: Sat Nov 07, 2009 6:52 pm
First name: Heath
Last Name: Blair
City: Visalia
excellent. im glad to hear its fixable. so i have to do some soldering? sounds scary.
thanks for helping me out guys.
how about the placement of the condenser mic?
Users browsing this forum: peter.coombe and 27 guests
