It is currently Tue Aug 05, 2025 3:13 pm
 Post subject: Side bending concept
PostPosted: Sun Mar 22, 2009 7:49 pm
OK, do I have the basic side bending concept down, or am I missing it?
Here's what I understand:
1. You can begin bending sides at around 220 - 240 ( When you see the steam start rising from the blanket.
2. You can begin to bend almost any wood (maple, mahogany, plain bubinga, lightly figured koa) at this temperature range.
3. Once you have the wood bent, you need to bring different types of wood, as mentioned above) to different temperatures, some higher than others ( per John Mayes suggestions) and hold it there for 5-7 minutes.
Or:
Do you actually need to bend the different woods at different temperature ranges before holding them at a certain temp?
I am basically using a sandwich consisting of:
Spring steel slat
Aluminum foil
wet kraft paper
wood
wet kraft paper
Aluminum foil
Spring steel slat
heating blanket
Thanks for any insite.
Bill
Sorry for the double post. I don't know how to delete it.
Formerly know as Mandodiddle.
 Post subject: Re: Side bending concept
PostPosted: Sun Mar 22, 2009 8:18 pm
once you see steam go for it. Otherwise your first scenario, per my instructions, is a very easy way to do it.
Users browsing this forum: Durero, Facebook [Bot], J De Rocher and 41 guests
