It is currently Mon Aug 04, 2025 10:45 pm
PostPosted: Thu Feb 26, 2009 12:50 pm
First name: joe
Last Name: kelly
City: glasgow
Country: uk
hi everyone.....do you guys know of a remedy for stopping my dyed black 0.5mm sycamore veneer lines from bleeding into my spruce tops when i use epoxy.....when i inlay pearl i like to us epoxy for more working time and i put the black lines and mop in at the same time...........i use zpoxy 30 mins and it just bleeds into the spruce.......any ideas????
joe
PostPosted: Thu Feb 26, 2009 1:12 pm
One way would be to seal your spruce top with shellac before gluing the rosette, particularly the end grain. Why not use CA for this application?
Laurent Brondel
West Paris, Maine - USA
PostPosted: Thu Feb 26, 2009 1:37 pm
First name: joe
Last Name: kelly
City: glasgow
Country: uk
hi Laurent....i have always thought that the epoxy would have trouble sticking to the sealed areas......i will give ca a go tommorow......would i use the thin viscocity for this job?.....thanks for your help
joe
PostPosted: Thu Feb 26, 2009 3:15 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I use medium CA, but the purfling is already glued in, I like the teflon technique for doing my pearl. I run a little CA in the trough slightly past where the next piece is to go and press the pearl into it, I just keep working around the rosette until complete. It should also work with putting the Purfling in at the same time. A little CA pushes up in any gaps and around the edges, this sands off easily when hardened.
Once the pearl is mitered I remove it from the trough and start gluing, it goes real fast. I have also put the pearl in place and wicked thin CA down the edges, but thought that it did not fill any gaps as well and the medium CA. The Medium CA prevents the finish shrinking into the seams, actually the only way one can see where the pieces are jointed is by the slight color or pattern change.
Fred
Fred Tellier
Users browsing this forum: peter.coombe and 40 guests
