It is currently Sun Aug 03, 2025 4:07 pm
 Post subject: Best plunge router bit?
PostPosted: Wed Dec 03, 2008 5:00 pm
I burned up my upspiral 1/4" bit hogging out mahogany for a dovetail neck connection. I use my dovetail bit to do the final cuts. What do you guys recommend for a good router bit for the job?.
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Wed Dec 03, 2008 6:50 pm
First, table saw as much as possible then use the router to finish the job.
I use carbide endmills. Wood is often harder on tool bits than steel.
PostPosted: Wed Dec 03, 2008 7:13 pm
I waste out dovetail mortises with a 1/2" dia ocemco spiral bit with a plunge tip.
I think that a 1/4" bit is a little skimpy for the job.
-C
Freeborn Guitars
and home of BeauGuard©
PostPosted: Wed Dec 03, 2008 9:46 pm
Last Name: Garrish
The cost of router bits is actually insane compared to end mills now. It's funny, but I think it's mainly because it's mostly hobbiests buying router bits so they're not prone to shop around. Anyhow, buy carbide end mills unless you need a bearing on it.
Bob Garrish
