It is currently Sun Aug 03, 2025 7:20 am
PostPosted: Sat Nov 15, 2008 6:58 pm
Hello All,
I had an issue with my bandsaw and was unable to resaw some spruce billets as soon as I would have liked, I kept them moist so they wouldn't split knowing they would develop mold, which they have, any thoughts on how to get rid of the mold/process these billets at this point would be greatly appreciated.
Cheers,
Greg
Gwaltney Guitars
PostPosted: Sat Nov 15, 2008 7:09 pm
Bleach&water solution lightly sprayed on should do it.
PostPosted: Sat Nov 15, 2008 7:10 pm
Perhaps submerge for an hour or longer in a very strong solution of sodium hypochlorite (BLEECH).
Dan
http://www.acme-archtops.com
PostPosted: Sat Nov 15, 2008 7:21 pm
I was thinking about the bleach/water trick too, just wondering if that would penetrate the spruce at any depth and leave a stain, I wouldn't think so, just wondering though.
Greg
Gwaltney Guitars
PostPosted: Sat Nov 15, 2008 7:28 pm
It might tak away some stains,it won't leave any.
PostPosted: Sat Nov 15, 2008 7:32 pm
Last Name: MacDougall
I work in a furniture warehouse and we occasionally get batches in with mould problems. We just wash it off with alcohol - never had a recurrence reported. It might leave some surface staining on bare wood though..
Bri
PostPosted: Sat Nov 15, 2008 7:34 pm
Letting the wood dry is the best prevention and the only real way to stop the mold. You can't really kill it as it will come back if the wood is over 20% EMC. Why on earth did you keep it "moist" ??? I have never heard of that and I have dried a lot of wood. Usually by the time you have mold on a light colored wood like spruce your done. Maybe you could bleach it but I wouldn't bet on a good result. What is wrong with the time honored method where you seal the end grain and let the wood dry. Once it is under 20% EMC mold won't grow. The only time I would keep wood "moist" would be if I wanted spaulted wood. Your spruce billets should split if you handle them properly.
Link
PostPosted: Sat Nov 15, 2008 7:40 pm
Hey Greg, if it were me I would just start processing them, saw the mould off. If that is not the way you want to go then soak the billet in a tub of water for an hour to saturate it, then soak in bath of bleech, the cells will then not let the bleech penetrate as they will already be full with water.
Good luck!
PostPosted: Sat Nov 15, 2008 8:32 pm
Oops
That should read : "Shouldn't split"
Link
PostPosted: Sat Nov 15, 2008 8:58 pm
Oops
Link
PostPosted: Sun Nov 16, 2008 12:31 am
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
Hydrogen peroxide may be another option for you. I know that it kills some molds. It will act as a bleach though, so you may want to test it out first.
Darrin
PostPosted: Sun Nov 16, 2008 12:56 am
Last Name: Walden
City: Bartlesville
State: Oklahoma
Zip/Postal Code: 74006
Doesn't bleach get a little kick with sunlight? I wonder if a light spray with diluted bleach and then a little sun would do it.
In the paper industry they used to use sodium hypochlorite (bleach) to whiten paper pulp but now have to use hydrogen peroxide because of the former releasing chlorine into the waste stream.
Good luck,
Steve Walden
Aspiring Builder,
Bartlesville, OK
Users browsing this forum: bobgramann and 21 guests
