It is currently Sat Aug 02, 2025 9:51 am
PostPosted: Wed Nov 05, 2008 11:19 am
What's recommended to clean up epoxy off a finished instrument? I'm obviously going to try my best to not get the stuff where I don't want it, but best to check just incase!
I'm worried that most of the solvents that will touch the epoxy will also have a good go at the finish.
Ta
Andy
PostPosted: Wed Nov 05, 2008 11:56 am
Assuming you are talking about wet epoxy, I use mineral spirits, but naphtha will also work fine without affecting finish.
PostPosted: Wed Nov 05, 2008 12:00 pm
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
I dont know how it reacts with finish...but WD 40 is good for removing wet epoxy. Really gets it off your fingers and tools.
Darrin
PostPosted: Wed Nov 05, 2008 12:02 pm
Yeah I'm talking about wet epoxy :)
Thanks for the replies chaps!
WD40 is not a go-er though. Never get that stuff on unfinished wood :shock:
PostPosted: Wed Nov 05, 2008 6:39 pm
Darrin
Do NOT use WD40 for this on anything you later want finish to adhere to. WD40 is a silicone oil and silicone is anathema to just about every finish medium I can think of.
Alcohol cleans up epoxy resin well. Use neat ethanol, methylated sprit or IMS. Isopropyl alcohol (isopropanol, propan-2-ol) doesn't work so well and is best avoided.
Ian
PostPosted: Wed Nov 05, 2008 7:29 pm
Tips worked, glues drying.
Ta chaps
