It is currently Sat Aug 02, 2025 3:40 am
 Post subject: Turnbuckle spreaders
PostPosted: Thu Oct 09, 2008 9:26 pm
Not sure what you would call them, but where is the best place to buy the turnbuckle spreaders that you use to hold the rim tightly in the mold? thanks
 Post subject: Re: Turnbuckle spreaders
PostPosted: Thu Oct 09, 2008 9:31 pm
Daniel,
I'm not sure where you live. I found a wide selection at my local
(regional) "Orchard Supply Hardware" here in California. I'd expect that
any large hardware/building supply place would stock them.
Look in the section where fence-building hardware is shelved, as I believe
their intended application is to provide diagonal tension in fence gates.
Eric
PostPosted: Fri Oct 10, 2008 3:19 am
Marine suppliers are a good source down here in Australia.
PostPosted: Fri Oct 10, 2008 4:50 am
First name: Allen
Last Name: McFarlen
City: Mt. Sheridan
State: Qld.
Zip/Postal Code: 4868
Got mine in a dedicated bolt and fastener shop. They've got them in all flavors. Cheapest by far where the galvanized ones used for farmer's fencing. $1 each.
Allen R. McFarlen
Facebook
Cairns, Australia
PostPosted: Sun Oct 12, 2008 7:30 pm
Lowes and Tractor Supply
Red
We Bend the Wood, So You Can Bend the Strings
PostPosted: Sun Oct 12, 2008 7:39 pm
I wish they were a $1.00 here.I just use threaded rod with a wingnut reversed and a washer.
PostPosted: Sun Oct 12, 2008 7:47 pm
First name: Pete
Last Name: Liccardello
City: Eden Prairie
State: Minnesota
Check your local ACE hardware. They usually have a good assortment and the prices are reasonable.
YMMV
Peter
PostPosted: Sun Oct 12, 2008 8:01 pm
When they put a lowes store in nearby all the local ace hardware stores closed up.And they are expensive at lowes.So i use the threaded rod which i like alot.Thanks anyway,Mark
