It is currently Sun Jul 27, 2025 1:51 pm
PostPosted: Tue Jun 24, 2008 10:53 am
First name: Chuck
Last Name: Hutchison
City: Houston
Has anyone used a drill press for binding? I wouldn't think a drill press would have enough RPM for the job. A drill press would keep the bit vertical also. One could make a table to hold the guitar level to rotate under the bit and lower and raise the chuck as needed. Try to fit a disc on the chuck for the bit to ride on the edge of the guitar.
PostPosted: Tue Jun 24, 2008 10:56 am
No, but I have built a jig to do what you are thinking.
It was a 2'x2' piece of MDF with a big "arm" that comes over it and suspends a lam trimmer. I put the LMI binding bit set in it and it works great.
I use it to bind carved top electrics. It cuts the channel an even distance from the "BACK" of the guitar and helps deal with the carved areas.
Works like a champ.
PostPosted: Tue Jun 24, 2008 12:41 pm
A standard drill press has insufficient speed (rpm) for routing a clean cut.
PostPosted: Tue Jun 24, 2008 1:50 pm
First name: Chuck
City: Houston
I kinda thought it wouldn't have.
Thanks Brock and Barry
PostPosted: Tue Jun 24, 2008 2:14 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I just finished building my Williams Jig, can't wait to try it out.
Users browsing this forum: Bing [Bot] and 24 guests
