It is currently Sat Jul 19, 2025 6:48 pm
 Post subject: Preamp advice
PostPosted: Thu Jan 31, 2008 3:40 pm
City: Grandfalls
State: Newfoundland
Hey Guys....When someone wants the option of being able to plug their acoustic guitar into a sound system....What do you recommend?....Pre amps look great but you have to cut that hole in the guitar side.....The option that I like is the double piezo glued to the bridge plate and wired directly to the plug in jack....What do you use and if you use a preamp do you do anything to reinforce guitar side when you cut the hole......Larry
 Post subject: Re: Preamp advice
PostPosted: Thu Jan 31, 2008 3:46 pm
Don't cut holes for preamps. They will probably be replaced eventually with new technology and then you'll be left with a big hole in your guitar. I use either simple, on-board, jack mounted preamps or off-board, belt clip or microphone stand mounted preamps.
PostPosted: Thu Jan 31, 2008 3:53 pm
I highly suggest if you use a in body preamp you reinforce the are where the preamp screws into the body. about 80% of the ones I have seen come into my shop one or more of the screws are loose and not holding and often the hole for the screw has cracked through to the cut-out for the preamp.
As far as the pickup element its self there are a wide variety from mics to transducers of many arrangements and combinations of both.
as far as direct output systems I like K&K Pure Westerns, LR Baggs M1 and M1a. If I had my rather I would prefer to use something like the M1 and M1a for their ease of removal.
PostPosted: Thu Jan 31, 2008 4:35 pm
Ditto what Barry said. Use the undersaddle transducer with a belt-or-microphone mounted preamp. K&K sells one that is matched to their systems. Actually they sell a couple.
Wes McMillian
Santo, TX
http://www.wesmcmillian.com
PostPosted: Thu Jan 31, 2008 4:43 pm
Check out my D-TAR Solstice preamp. We call it the "Swiss Army knife" of preamps.
http://www.d-tar.com
Disclaimer time: Yes, I'm the "T" in D-TAR, and I'm financially tied to the company
PostPosted: Thu Jan 31, 2008 11:38 pm
Take a look at the MI-SI batteryless preamp. Electronics are on the end pin. Plug a charger into the jack for a minute and you are good to go for 8 hours plugged into an amp. This preamp uses the Baggs under saddle pickup. They make other preamps with tone and vol controls accessible through sound hole.
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Fri Feb 01, 2008 12:54 am
You should listen to certainly listen Rick on amplification issues, he's lived it for a long time and a great reputation in the area.
In addition if for some reason that option won't work for you, you could check out the LR Baggs Paracoustic DI box.
PostPosted: Fri Feb 01, 2008 12:56 am
Larry, the pickup in my guitar is a B-Band UST. I plug into an Avalon U5 and go straight to the house from there. The U5 pricey, but it gives me a full, rich sound.
PostPosted: Fri Feb 01, 2008 12:35 pm
Hello Everyone,
I have been lurking for awhile to pick your brains. I just starting my first guitar project. This is my first post.
I have playing gigs for quite a while and have some experience in this area so I thought I might add something. Larry, I use LR Baggs pick ups in three different guitars. I have used their Gig Pro pre-amp and also the Para DI. both are excellent and stand alone as are D-tar's. I have played them through both an acoustic Amp and a Pa system. The controls are fairly simple and intuitive for a player.
Woody O'Keefe
Woody O'Keefe
PostPosted: Fri Feb 01, 2008 2:09 pm
Welcome to the forum Woody!
PostPosted: Fri Feb 01, 2008 2:44 pm
Welcome Woody, from Waddy! :D
